Hello.
my techs have broken a lot of rf cables from the Force 110 parabolic dish.
What kind of internal connectors are used?
RP-SMA on one side, and on the internal side?
Hello.
Anyone have a source for these in the US? I can't find anyone selling them, just the ubiquitous u.fl to female rp-sma bulkhead connector used on so many wifi routers.
j
http://www.balticnetworks.com/u-fl-to-right-angle-sma-pigtail-8-inch-23-cm.html
or
http://www.balticnetworks.com/mmcx-to-right-angle-sma-pigtail-8-inch-23-cm.html
I work for Kudos & The "Accept as Solution"
Just a reminder:
Those cables listed in the post above won't work, those are standard "SMA" threaded connectors, where you actually want the "RP-SMA" types.
So, you are looking for a coax fitted with a "male" RP-SMA / "plug" RP-SMA / "RPSMAM" on one side, and a U.fl on the other.
The devil is in the details I missed the rp part, opps. But my chance for redemption! in my conversation with baltic this morning I brought this up and they can get these custom made at a reasonable price at the lowest quantity that you want since we have broken some of these cables ourselves I asked for a price and lead time.
