Hello family
I’m John
I have a problem with the epmp 2000 when I turn on all works fine but when I try to access the interface via the IP address 192.168.0.1 its not even entering with the 169.254.1.1 still nothing.
In the software cambium discovery tools sa displays only the MAC address.
Can you describe the physical setup? Are you directly cabled to the ePMP, or through a switch or router? Have you configured your PC to be in the same subnet as the address you are trying to access?
I connect the equipment directly to my PC so the data port of the Poe power supply directly to the network card of my PC
I also configured my pc on 192.168.0.100
Set your pc to 169.254.1.100/24
Then ping 169.254.1.1 if that works, then use your browser to access the AP. If not perform a factory reset and try again.
Please change the network cable from the radio to the PoE.
Sometimes, when cable is not crimped well, the LAN side does not comes up.
Consider an originally crimped cable or take your time to crimp the cable - the both sides.
You should be able to reach the radio.
