IPTV Multicast multiple streams per SM
Hi.
Should ePMP2000 and 3000 support multiple Multicast streams per SM? Use case is that client has multiple IPTV set top boxes.
https://community.cambiumnetworks.com/t5/ePMP-Networking/ePMP-Multicast-Configuration-amp-Use-Cases/td-p/76201
Thank you.
Hi AnzeZ,
Yes, it should work without a problem. Have you ran into any issues?
Dmitry
Hi.
Thank you for info.
Yes, we had a client that said it doesnt work. We will show them wrong. :slight_smile:
We didn’t have problems yet with multicast, always worked as it should.
Kind regards
