is it possible to ‘daisy chain’ 2 CMM’s? seems like you could but not sure. any tips on that?
when you say "daisy chain in what regards are you referring to ? otherwise you could just leave on port on each unpowered and run a patch cable between them.
No, each cmm needs its own gps antenna
