Today we installed a new antenna out of the box and found that it is missing the serial number in the GUI.
Please tell me how this can be fixed without replacing the antenna?
Hi, Did you tried factory reset ?
That sounds like the same problem as this:
It’s impossible now, I have only remote access
yes - same issue 100%. Today we started using 4.6.0.1 on new installations and I have two antennas with the same problem.
Other antennas that have already been connected to cnMaestro and upgraded remotely are working well.
