Hello there,
We are looking to create a configuration template that will add multiple color codes as secondary priority to some of our 450 SMs. Based on the configuration I exported from one radio with those settings configured by the GUI, it should look something like this:
{ "userParameters": { "smRadioConfig": { "colorCodeList": [ { "colorCode": 131, "priority": 2 }, { "colorCode": 132, "priority": 2 }, { "colorCode": 133, "priority": 2 }, { "colorCode": 134, "priority": 2 } ] } } }
The template saves properly in cnMaestro, so no big json syntax errors, but when applying to the radio I get a "Configuration Import Failed" message. Am I doing this wrong?
