Hi experts,
I have created a json to run in CnMaestro to change the password and channeL bandwidth scan that works correctly in the SMs that are connected to APs without authentication key enabled but if I run it to SMs where is this enabled it takes not effect.
The Json File is:
"userParameters": {
"smRadioConfig": {
"bandwidthScanList": [
200, 300
"authenticationConfig": {
"whispWebUserAccessMode": 2,
"allowRejectThenLocal": 1,
"authenticationKey": "",
"accounts": [{
"userName": "admin",
"level": 3,
"readOnly": false,
"passwordEncrypted": "4e1547f0e06d337fdd3ef6759ae45897"
"userName": "root",
"level": 3,
"password": "${password=XXXXX}",
"readOnly": false
"authKeyOption": 0
"cfgFileString": "Canopy configuration file",
"cfgFileVersion": "1.0"
The SMs are running in 16.0.1 software version.
Any idea?
