Json QOS speed change template
Below is the JSON format I am trying to use to change the downlink and uplink rates on an SM.  It isn't updating and rebooting.  Could anyone lend a hand?
"qosConfig": {
"uplinkBurstAllocation": "250000",
"largeVCQ": "0",
"prioritizeTcpAck": "1",
"sustainedUplinkDataRate": "1000",
"sustainedDownlinkDataRate": "3000",
"downlinkBurstAllocation": "250000",
"maxDownlinkDataRate": "0",
"maxUplinkDataRate": "0"
"configFileParameters": {
"rebootIfRequired": true
"cfgFileString": "Canopy configuration file",
"cfgFileVersion": "1.0"
Thanks!
Try the following instead.
	"userParameters": {
		"qosConfig": {
			"largeVCQ": "0",
I placed the configuration parameters within "userParameters" and removed "configFileParameters".  "configFileParameters" options are not applicable when making configuration changes via cnMaestro.  cnMaestro tells the device to reboot automatically, if required, to fully apply the configuraiton template.
If you are uploading a configuration file directly to the device via its web UI, then add "configFileParameters" back.
