L3 routing on Switch
Hello,
I am trying to use Layer 3 routing option on EX2028P, to avoid the traffic to go through the Firewall. And have Inter-VLAN communication done at Switch level. However, when i am trying to add a route to my table in advanced setting and i am getting the below error.
Also if i look into device configuration, i do not see IP Routing enabled even if i use CLI to enter that command. Is there any way to enable IP routing via cnMaestro ?
Hi @Arshdeep_Singh ,
Thank you for sharing the details and the screenshot.
This error is commonly seen when there is an issue with the destination network(Network IP of the subnet) configuration; we recommend reviewing the values to ensure they are correct.
Could you please share the exact configuration details you are using for the route entry?
Specifically, we need:
  • Destination Network
  • Subnet Mask
  • Next Hop IP address
Thanks in advance..
Regards,
Ashok
