Hi All,
I don’t know why the right led (PoE) is off even if I can see the connected device up and running and the cnMaestro indicates to me the “POE Detection status” is “Delivering Power 2.8 W”
I already tried to reboot the switch… and the “sync status” is “in sync”
Any other idea ?
Stef
Was the LED on before for this port? Does the PoE LED work for other ports? What is the switch model and its software version?
Thanks.
Yes the led was up before some modifications
This is a 1028-P model with recommended version
3.2.2-r3
and when I disconnected the device from port 19 to 18… the poe led was up for the port 19 (even there is no device connected to it…) strange … after the reboot the led of the port 19 was down
S
