I am having issues with LIFX wifi bulbs and Cambium e400 WAPs.
To set up the bulbs, you need to use the LIFX mobile app. Trying to set up the bulbs takes multiple efforts but I can usually eventually get it to work. Once set up, the bulbs usually work well for a while. But periodically they refuse to connect to the network and I have extensive issues trying to get them to reconnect. There might be some kind of cache issue, since changing the wifi SSID to something new usually seems to help.
I've reviewed the error logs from the WAPs. It looks like the client repeatedly tries to connect, something happens, connection fails, then repeat. The following seems to be a relevant extract (the MAC address is for a LIFX bulb, vlan should be 24, and SSID skyfiIOT__ (suffixes added to change SSID only). I've confirmed my router + WAP config does setup does work, however not reliably.
Jun 21 13:45:35: wifid : Client[D0-73-D5-12-7E-12] on ssid skyfiIOTau internal cache based vlan is 0 (apd.c:127)
Jun 21 13:45:35: wifid : Client[D0-73-D5-12-7E-12] on ssid skyfiIOTau assigned WLAN vlan 24 (apd.c:141)
Jun 21 13:45:35: wifid : client [D0-73-D5-12-7E-12] on ssid skyfiIOTau vlan 24 state sync (type:1) sent, len[128] (cache.c:1767)
2020-06-21 13:45:35 573 wifi.c:1307:set_log_level: syslog severity=7
2020-06-21 13:45:35 573 wifi.c:1949:event_rx_cb: Trap Data received, send to cnMaestro len=230 data [{"msgType": 699, "eId": "WIFI_CLIENT_CONNECTED",Jun 21 13:45:35: scmd : Jun 21 13:45:35 WIFI-6-CLIENT-CONNECTED Client [D0-73-D5-12-7E-12] connected to wireless lan [skyfiIOTau] (mai
Jun 21 13:45:35: snmpd : system trap has been sent (snmpd.c:1382)
Jun 21 13:45:35: wifid : client[D0-73-D5-12-7E-12] on vap_id[4] wlan_id[4] created in coplane (stats.c:227)
Jun 21 13:45:35: wifid : client[D0-73-D5-12-7E-12] ga[0]:ci[0] sta ssid[4][skyfiIOTau]:cache ssid[skyfiIOTau] (cache.c:2550)
Jun 21 13:45:35: wifid : 2020-06-21 13:45:47 573 log.c:207:start_cns_logging: Send log history (10 lines)
Jun 21 13:45:35: wifid : radio_idx=0, bss_idx=4, APD_NUM_RADIOS=2, APD_NUM_BSS_PER_RADIO=16 (apd.c:539)
Jun 21 13:45:35: wifid : client[D0-73-D5-12-7E-12] hostapd vlan=24 and wlan vlan=24 (cache.c:1678)
Jun 21 13:45:35: wifid : client[D0-73-D5-12-7E-12] no hotspot session found (hotspot.c:977)
Jun 21 13:45:35: wifid : apd: Client[d0:73:d5:12:7e:12] sent 0 PMKID in (Re)association request (log.c:51)
Jun 21 13:45:35: wifid : apd: get vlan: 24 (log.c:51)
Jun 21 13:45:35: wifid : Client D0-73-D5-12-7E-12 moved to data ready state (stats.c:581)
Jun 21 13:45:35: wifid : client D0-73-D5-12-7E-12 ci_sess current state[NOT_IN_USE] moved to new state[IN_USE] (stats.c:505)
Jun 21 13:45:35: wifid : client D0-73-D5-12-7E-12 ci_sess current state[IN_USE] moved to new state[AUTHENTICATED] (stats.c:505)
Jun 21 13:45:35: wifid : client [D0-73-D5-12-7E-12] on ssid (null) vlan 24 state sync (type:6) sent, len[672] (cache.c:1767)
2020-06-21 13:45:35 573 wifi.c:1949:event_rx_cb: Trap Data received, send to cnMaestro len=495 data [{"msgType": 699, "eId": "WIFI_CLIENT_DISCONNECTEJun 21 13:45:35: scmd : Jun 21 13:45:35 WIFI-6-CLIENT-DISCONNECTED Client [D0-73-D5-12-7E-12] disconnected from WLAN [sk2020-06-21 13:45:47 573 log.c:207:start_cns_logging: Send log history (10 lines)
Jun 21 13:45:35: wifid : client[D0-73-D5-12-7E-12] hotspot session updated ga_allowed[0] to coplane (hotspot.c:401)
Jun 21 13:45:35: wifid : client[D0-73-D5-12-7E-12] on vap_id[4] wlan_id[4] deleted in coplane (stats.c:227)
Jun 21 13:45:35: wifid : Disconnect Detail: mac=D0-73-D5-12-7E-12 rssi=47 reason=client-sent-deauth-with-frame-8-rssi--64 (log.c:190)
Jun 21 13:45:35: wifid : station D0-73-D5-12-7E-12 disconnected, reason code=8:Station Left BSS (stats.c:2199)
Googling the "reason code 8" error suggests that the issue might be redirection to another AP (I have 3). However, I have tried separate IOT SSIDs for each of my WAPs (skyFiIOTa, b, c etc.). That does seemt to help with connecting, but doesn't improve long term stability.
The LIFX bulbs connect fine to consumer/ISP supplied routers so I'm reasonably confident the issue is with my config somewhere.
I've also had some issues with other IOT-type devices, I suspect based on the ESP8266 platform but I've gotten rid of those.
