Link Distance
What is the recommended link distance for ePMP Force 200-25.
Regards,
K.Esakki
That's a really open ended question that requires more information and taking a number of factors into consideration, like required bandwidth, the band and EIRP restrictions, noise floor, etc. The best way to figure out if the F300's will work for a particular link and application is to plug the data into Cambium's free tool called LinkPlanner. This will also allow you to compare the F300's to other radios from Cambium quickly and easily.
Saludos Como te indican es una explicacion muy amplia, pero tengo enlaces a 33Km con Force 200 pasando unas 150Mbps agregados. y en zonas con un poco de ruido.
