HI
Can anyone please share the old link 5.4.7 Link planner version .
HI
Hi Sameer,
We don’t support obsolete versions of LINKPlanner. You will also find that 5.4.7 is no longer able to fetch path profiles automatically.
You need to be running at least 5.7.0 if you want to to use the path profile service.
Andy
hi
can please share the link for same 5.7.0.
Thank for reply , am trying do use LP online where am facing issue to import KMZ file. getting error .
Hi Sameer,
Send the file to linkplanner@cambiumnetworks.com and we’ll investigate the problem.
Andy
