Link Planner Error [Errno 10061] target machine actively refused
Hi all,
I want to know, why my Link Planner doesnt want to connect to Internet.
I already check the proxy and firewall, but there is no issue.
The error displayed like this when i generate my Profile Path
Maybe someone of you have a solution?
When LINKPlanner requests a path profile, it makes a call to http://linkplanner.cambiumnetworks.com/config. This is the same as the “Test networks settings” button in the Options → Network Settings panel.
Follow the steps on How to Obtain Path Profiles?. If you are behind a proxy, take note:
LINKPlanner only supports “HTTP Basic” authentication, so if the proxy requires anything else, LINKPlanner cannot connect. This is most often caused by a setting with Microsoft’s proxy server, which by default only supports NTLM authentication.
The most likely cause of this error is a proxy server issue. Try to connect through a different network to see if that resolves the problem. Allow all HTTP traffic to linkplanner.cambiumnetworks.com and pathprofile.cambiumnetworks.com.
Andy
