We are working on a proposal for PMP network. We are using Link planner and we seem to have a problem with the terrian data. I am in Alaska and would like to use our terran data which is extremely accurate. Could you please let me know if there is any other way for exernal or other data sources.
If you are using high resolution data then you may run into issues. High resolution data will impact the performance and the file size. The prediction models have not been validated for high resolution data.
