Linking this Knowledge Base article that @Hamish put together for clients that require an external proxy server for CBRS operation.
Hopefully, this is helpful if you are looking into deploying an external proxy.
Evan,
Evan,
Has anyone actually got this to work successfully? It won’t even start the service using this configuration file.
What OS are you using here @Matt_Fridenstine? If you could show the error you get we can try to get it working for you. I’ll update the howto, but please try uncommenting the “port” line in the config if you’re using an older version of squid.
