Good afternoon,
I was looking at the version 4.8.5 of LinkPlanner so that I could model some of my cnReach N500 radio shots in a PMP mode, and check some shots to potentially displace some old radios with ePMP 2000s and some Force 200/300 units.
Of the 100+ radio links I have modeled with LinkPlanner, almost 100% are cnReach PTP shots. Imagine my suprise when I went to import my 4.7.4 saved project into the 4.8.5 version, and it threw away the couple of non-Cambium antennas we standardized on that were not on the original materials list, and changed the modulation mode on every cnReach shot. The import generated a 45 page (8.5" x 11") report of all the known errors.
(1) Was there a reason why the ISM/DTS (600 kHz)/BPSK modulation mode was dropped from the cnReach radio line in LinkPlanner, and if so, will the next cnReach firmware release align with LinkPlanner modulation modes? If so, we will have to re-model, verify, and change the 60 or so cnReach units we already have in the field. As and inpoint in an industrial process in an urban setting, we are more interested in endpoint reliability/availability/sensitivity than throughput, but as robust are Cambium radios are, most will probably still work at the minimum 99.9% we are modeling to.
(2) Is there any secret option to import the current 350 site, 103 PTP link project into LinkPlanner 4.8.x, without dropping the non-Cambium-approved "added antennas", and having to add and go back and correct both ends of about 100 PTP links? I cannot think of any way to add the antenna into the "LinkPlanner antenna config master" before I import/open the old project. On a related note, see (3).....
(3) I read through another forum entry where it was noted you can add antennas into a project, using the "other" selection in the dropdown for antennas. Much easier than backing out to the PTP antenna option, new antenna. I tried adding multiple antennas through both methods, and they do not show up as an option for the link. The antennas are listed in "PTP antennas" list as options, flagged at 900 MHz, appear in the master PTP antennal list once I add them, and the link is set for "vertical" polarization, yet no net new antennas show up as options. I can add and delete them at will, but I cannot select them for my N500 radio link, unless I am missing something. I stuck with a large, high-gain omni: PCTel MFB9157NF, 8', 7dB/9.14dBi, if it matters.
(4) Due to LOS and NLOS issues with attempting to convert leased line facilities to cnReach radios, we have a general site GPS location for each of 350 sites. As we "look around" on GoogelEarth and model the shots on LinkPlanner, it becomes obvious that one corner or area will make a better location than another. The only way to currently model this is add another network site with the slightly different GPS coordinates, and once again step through the end elevations, losses, etc. Can I ask for a "feature" where this can be changed, similar to the way the elevation can be changed, and the path is re-caled and modeled on the fly, with updated information?
Tried to paste in some snapshots, but I can't seem to make that work. Let me know if that is confusing.
At least one kudo, also: I appreciate the fact that I can re-install and revert back to an older version of the LinkPlanner software at will, without any issues. Back to 4.7.4, for now.
Thanks for your time,
KRather
