andreas_b
(andreas_b)
#1
Running LinkPlanner 5.6.5 and made a 60Ghz project, however the performance summary shows no DL modulation, bug ?
Regards
Andreas
Hi Andreas,
Unfortunately it is a bug. Here is the patch to fix the problem:
cnwave_60ghz.zip (12.2 KB)
To install the patch on Windows:
- Close LINKPlanner
- Download the attached zip file to a neutral location such as the desktop. Unzip it and extract the files.
- Open the LINKPlanner installation directory in Explorer (e.g. <C:\Program Files\Cambium Networks\LINKPlanner>)
- Navigate to the folder “link_planner\equipment\products”
- Place “cnwave_60ghz.pyc” in the “products” directory
- Start LINKPlanner
To install the patch on MacOS:
- Close LINKPlanner
- Download and unzip the attached patch
- Open the “Applications” folder in Finder
- Right-click on “LINKPlanner.app” and click “Show Package Contents”
- Navigate to the folder “Contents/Resources/lib/python2.7”
- Unzip “site-packages.zip”
- Remove the “site-packages.zip” file (if it is still there) to leave a “site-packages” folder
- Navigate to the folder “site-packages/link_planner/equipment/products”
- Start LINKPlanner
Let me know if you have any problems with it.
This issue has been fixed in the online version (6.0.1) and the fix will be included in the next desktop release.
Andy
