Sorry, I can't seem to add an attachment. Paste the text below "--" into a new text file and rename it "Antenna issue demo.ptpprj" and you should be able to open this in LinkPlanner and reproduce the issue.
Antony
<?xml version="1.0" encoding="UTF-8"?>
<LinkPlanner file_version="2.0" app_version="4.1.1">
<MetaData>File created on Sat Nov 08 14:01:22 2014</MetaData>
<Project model="ITU-R">
<Antennas>
</Antennas>
<AccessPointAntennas>
<Antenna id="d5d232e2-a5db-43c1-81a8-8ae301a7f8eb" diameter="0.609600000931" description="Test" old_index="None" partno="Part" diameter_units="feet" beamwidth="90" internal="0" dual="1" user_defined="1" permitted="{"5.8": "ePMP 1000", "5.4": "ePMP 1000"}" manufacturer="Miscellaneous 90deg">
<Gain band="band54" value="14.0"/><Gain band="band58" value="14.0"/>
</Antenna>
</AccessPointAntennas>
<SubscriberAntennas>
</SubscriberAntennas>
<CustomFields>
<CustomFieldSet kind="access_point">
</CustomFieldSet><CustomFieldSet kind="end">
</CustomFieldSet><CustomFieldSet kind="hub">
</CustomFieldSet><CustomFieldSet kind="link">
</CustomFieldSet><CustomFieldSet kind="place">
</CustomFieldSet><CustomFieldSet kind="project">
</CustomFieldSet><CustomFieldSet kind="subscriber">
</CustomFieldSet><CustomFieldSet kind="subscriber_place">
</CustomFieldSet>
</CustomFields>
<CustomValues>
</CustomValues>
<Templates>
</Templates>
<TddSyncGroups>
<TddSyncGroup frame_duration="0" max_burst_duration="0" v2="1"/>
</TddSyncGroups>
<Rules>
<Rule name="Does not meet requirements" format="1" stop_execution="0" disabled="0" boolean="any" excluded="0" hidden="0" format_settings="{"colour": "#ff0000"}" description="Link fails to meet performance requirements or has warnings">
<ExpressionGroup boolean="any">
<Expression comparison_value="False" predicate="equal to" property="link_ok">
</Expression>
</ExpressionGroup>
</Rule>
</Rules>
<Places>
<Place place_id="0" label_delta_y="0" label_delta_x="0" name="Network site" longitude="0.0" shape="circle" latitude="0.0" height_asl="None" maximum_height="10"><CustomValues>
</CustomValues>
</Place>
</Places>
<SubscriberPlaces>
<Place place_id="0" label_delta_y="0" label_delta_x="0" name="Subscriber 2" colour="#55a4f3ff" longitude="0.001" shape="circle" latitude="0.0" height_asl="None" maximum_height="10"><CustomValues>
</CustomValues>
</Place><Place place_id="1" label_delta_y="0" label_delta_x="0" name="Subscriber 1" colour="#55a4f3ff" longitude="-0.001" shape="circle" latitude="0.0" height_asl="None" maximum_height="10"><CustomValues>
</CustomValues>
</Place>
</SubscriberPlaces>
<Links>
</Links>
<Hubs>
<Hub place_id="0" name="Network site">
<CustomValues>
</CustomValues>
<AccessPoints>
<AccessPoint antenna="9cf914e2-85c7-4418-bdc5-f04386d78650" label_delta_y="0" label_delta_x="0" antenna_azimuth="270" tilt="0" use_noise="0" number="1" noise_density="-90" shape="triangle" antenna_height="10" user_power="None" receive_target_level="-65">
<Equipment max_range="2" product="PMP58ePMP" dl_ul_ratio="75/25" capacity="N/A" color_code="N/A" license="GB_UnitedKingdom_80" aes_encryption="N/A" max_range_units="miles" adjacent_channel_support="N/A" downlink_data="N/A" sm_registration_limit="60" band="band58" bandwidth="20" phase1_end="Local" sync_source="Internal" control_slots="N/A" sync_input="N/A" high_priority_channel="N/A" broadcast_repeat_count="N/A"/>
<Subscribers>
<Subscriber antenna="9101b0d8-3f4e-45a1-8fa4-f055de7ded49" place_id="1" label_delta_y="0" label_delta_x="0" antenna_height="10" use_noise="0" noise_density="-90" shape="rectangle" user_cable_loss="0" dirty="0">
<Profile region_code="YE 11" reflection_height="None" profile_requested="1">
0.0,0.0,0
55.6597453966,0.0,0
111.319490793,0.0,0
</Profile>
<PMPLink/>
<CustomValues>
</CustomValues>
<BOM>
<OptionalExtras>
</OptionalExtras>
<UserEdits>
</UserEdits>
<CustomNotes>
</CustomNotes>
</BOM>
</Subscriber>
</Subscribers>
<CustomValues>
</CustomValues>
<BOM>
<OptionalExtras>
</OptionalExtras>
<UserEdits>
</UserEdits>
<CustomNotes>
</CustomNotes>
</BOM>
</AccessPoint><AccessPoint antenna="d5d232e2-a5db-43c1-81a8-8ae301a7f8eb" label_delta_y="0" label_delta_x="0" antenna_azimuth="90" tilt="0" use_noise="0" number="2" noise_density="-90" shape="triangle" antenna_height="10" user_power="None" receive_target_level="-65">
<Subscribers>
<Subscriber antenna="9101b0d8-3f4e-45a1-8fa4-f055de7ded49" place_id="0" label_delta_y="0" label_delta_x="0" antenna_height="10" use_noise="0" noise_density="-90" shape="rectangle" user_cable_loss="0" dirty="0">
0.0,0.0,0
55.6597453966,0.0,0
111.319490793,0.0,0
</Profile>
<PMPLink/>
<CustomValues>
</CustomValues>
<BOM>
<OptionalExtras>
</OptionalExtras>
<UserEdits>
</UserEdits>
<CustomNotes>
</CustomNotes>
</BOM>
</Subscriber>
</Subscribers>
<CustomValues>
</CustomValues>
<BOM>
<OptionalExtras>
</OptionalExtras>
<UserEdits>
</UserEdits>
<CustomNotes>
</CustomNotes>
</BOM>
</AccessPoint>
</AccessPoints>
<BOM>
<OptionalExtras>
</OptionalExtras>
<UserEdits>
</UserEdits>
<CustomNotes>
</CustomNotes>
</BOM>
</Hub>
</Hubs>
<CustInfo></CustInfo>
<Description></Description>
</Project>
<UI>
<Tree state="[[0], [0, 0], [0, 1], [0, 1, 0], [0, 1, 0, 0], [0, 1, 1], [0, 1, 1, 0], [0, 3], [0, 3, 0], [0, 4]]"/>
</UI>
</LinkPlanner>
