LINKPlanner report export pdf Chinese display issue
Dear Sir,
I did some Link plans and analysis work in Taiwan and as for the site name I use Chinese character names. It’s ok to browse in web browser, but when I try to export the link detail report as the pdf file. It seems the Chinese characters can’t be displayed normally in pdf file. It would be great if this issue could be fixed. Thanks.
Regards,
Huawei
Hi Huawei,
Sorry about this. We need to ensure that the PDF reports are using the correct font. We will try to fix this for the next release, but it may take more time.
Can you send an example project to linkplanner@cambiumnetworks.com so that we are able to test that the output appears as expected?
Andy
