LLDP does not disable in 3.1
We noticed a wierd increase in traffic on our network and traced it down to discovery protocol responses. It turns out in 3.1 LLDP can not be disabled via gui or cli. A roll back to 2.6.2 fixes the issue. Has anyone else seen this problem ?
update: it appears that 3.2 increases the problem, in 3.1 responses are every 5-10 seconds, but in 3.2 responses are every 1-2 seconds.
-B
Hi Ben Backus,
Could you execute and attach next commands:
on ePMP device CLI:
  show lldp-neighbors
on directly connected PC:
  lldpctl
Thanks.
running the neighbors command results in this
Officese-camb>show lldp-neighbors
LLDP neighbors:
It appears it does not see any neighbors
but our firewall tells a different story
Dec 8 10:35:08 WAN 172.17.4.65:5678 255.255.255.255:5678 UDP
Dec 8 10:35:01 WAN 172.17.4.65:5678 255.255.255.255:5678 UDP
Dec 8 10:34:58 WAN 172.17.4.65:5678 255.255.255.255:5678 UDP
Dec 8 10:34:55 WAN 172.17.4.65:5678 255.255.255.255:5678 UDP
Dec 8 10:34:48 WAN 172.17.4.65:5678 255.255.255.255:5678 UDP
Dec 8 10:34:38 WAN 172.17.4.65:5678 255.255.255.255:5678 UDP
Dec 8 10:34:31 WAN 172.17.4.65:5678 255.255.255.255:5678 UDP
Dec 8 10:34:28 WAN 172.17.4.65:5678 255.255.255.255:5678 UDP
Dec 8 10:34:26 WAN 172.17.4.65:5678 255.255.255.255:5678 UDP
Dec 8 10:34:19 WAN 172.17.4.65:5678 255.255.255.255:5678 UDP
Dec 8 10:34:15 WAN 172.17.4.65:5678 255.255.255.255:5678 UDP
Dec 8 10:34:11 WAN 172.17.4.65:5678 255.255.255.255:5678 UDP
Dec 8 10:34:07 WAN 172.17.4.65:5678 255.255.255.255:5678 UDP
Dec 8 10:34:04 WAN 172.17.4.65:5678 255.255.255.255:5678 UDP
Dec 8 10:33:55 WAN 172.17.4.65:5678 255.255.255.255:5678 UDP
Dec 8 10:33:51 WAN 172.17.4.65:5678 255.255.255.255:5678 UDP
Dec 8 10:33:44 WAN 172.17.4.65:5678 255.255.255.255:5678 UDP
Dec 8 10:33:32 WAN 172.17.4.65:5678 255.255.255.255:5678 UDP
Dec 8 10:33:28 WAN 172.17.4.65:5678 255.255.255.255:5678 UDP
Also the lldpctl command is not active in the shell from what i can tell.
-B
Has anything come  of this?
If anyone else has this problem it is fixed by setting: System "MAC-Telnet-Access" is disabled.
-Ben
