I have two 5.7BH modules that I can’t get into even using the default plug. I’m using the right network and mask and connections says I’m connected, but, can’t get into programming. Anybody else run into this?
Thanks for the reply Jerry. Problem solved - it was a bad PoE unit.
Can you telnet to it? Have tried a different computer?
