epmp4600c… Is this radio reliable for critical link? I mean is the fw stable and reliable, mature? Can I refer to linkplanner, is it accurate?
BTW AFC seem to be random from my experience, 1 given coordinate allow me to use every channel at 36eirp, and 200ft away I cant, a lot of busy channels. Probably something I didnt get duh.
It’s 100% reliable. You can find many stories f success with F4600 on that forum.
If you can give us coordinates, we can verify if AFC works as expected and there is no error there.
Feel free to reach out in DM to me.
To add a bit of extra information to this post. The AFC tool and link planner only shows licensed use. This means that other carriers in the area (including cambium customers) will not show up on the AFC tool. The only way to know the noise in your area at present is to get a radio in the air and run a spectrum with it.
As noted, the AFC only shows channel availability and EIRP, not what is in actual use. You will need to user the spectrum analyzer to determine that. PTP links are stable, though we do get an occasional RX KEEP ALIVE STUCK when using 160.mhz channels. 80 Mhz channel are very stable. Uptime counter from a PTP link we put up over 4 months ago running 5.9.2 that has not blipped at all and we’ve been through some pretty severe weather..
I Got my first link and i installed it today. First of all, is it normal that Wireless test doesnt match the real world speed? For exemple, I got 900mbps on receive using the built in wireless speedtest. When I do the test with a pair of mikrotik, I got only 230mbps on tcp and 700ish on udp. Is that normal ?
The vast difference between your TCP and UDP results would suggest it may be the CPU core running Btest on the Mikrotik’s that are maxing out. Plug a patch cable between the 2 Mikrotiks and repeat the test or better still, run iPerf3 or similar between 2 PCs over the link.
@aka Has there ever been any thought to having WLT have a TCP/UDP mode selector so we can do TCP tests, or is the CPU overhead too great to have the devices do TCP WLT?
