losing signal between subscriber and access point
Hi .i am losing signal between my epmp 1000 subscriber and my epmp 2000 access point .it is up for a few seconds and then down again for a few .showing that it is scanning .i am testing it first in the workshop .i also have another same subscriber but it does not fail.can someone please help me ?
From your SM, go to monitor and wireless, it will list the avaliable APs and a reason why its not connected to them. Sounds like a miss matched key is your likely issue
Hi Gordon,
After you will check Network Entry status, you can find Network Entry State definitions there:
http://community.cambiumnetworks.com/t5/ePMP-Troubleshooting/Network-Entry-State-Definitions-and-Courses-of-Action/m-p/40712#M8
Thank you.
