I am trying to understand why I am having low throughput on my AP with 5GHz on iPhone 6s using SpeedFlex.
I have set up an SSID which is 5Ghz only and have turned of all the roaming protocols and when doing an iperf to the unit using SpeedFlex the most I get is 120Mb/s. The test also fluctuates quite a bit. I also get similar results on an iPad.
I have the 5Ghz on 80Mhz and have tried varying the channels and radio power.
Anyone have ideas as to why I may be seeing this behaviour?
Thanks in advance.
Hi Shim,
Can you please download and share the techsupport of an AP to my email(mentioned below).
You can download techsupport from following location ::: Operations --> System and Download TechSupport
Email : ashok.kumar@cambiumnetworks.com
