hi i’m experiencing very cut of bandwidth with nat enable on some sm (also in OFDM) if i enable pppoe i’ve a cut of bandwidth of 50% towards link capacity test if i enable static ip of 30%
if i switch off nat and using canopy only as bridge the speed is correct (same speed of link capacity test)
some one is having same problem ?
thank you all
Is the SM running with latest software version?
allanpelais wrote: Hi,
yes 11.2 AP-DES
and the SM?
allanpelais wrote: and the SM?
Same on SM and AP
