@Jordan We are running cloud version…It appears I have 157 minor alarms that are for GPS firmware out of date. One example ePMP 2000 (Lite) running AXN_3.20_8174, both active and inactive banks are on 4.6.1…I know you will probably need more info than this but if nobody else on the forum is having the same issue then I will try to narrow down the issue to certain APs and a possible root cause before I waste your time to dig into it…These APs (approximately 140) have all either recently been upgraded or are currently being upgrade, so I will dig a bit deeper since the alarm should have been cleared after the upgrade…Thank you for the response and any further suggestions…
