Ok - I will be the first to kick off here ![]()
We have set up and powered up the B1000 and looking through the config and docs I cannot see how to set the Management VLAN or default VLAN on the AP. Is there a way to do this on firmware v1.0?
Hi!
Management VLAN was introduced in the B1000 in Release 1.1.
Please contact your local sales representative to obtain Release 1.1 SW images.
Once installed, you can configure the Management VLAN under System->General->Network->Management ID. A value of 1 means no VLAN tagging, values 2 to 4094 indicate the VLAN ID to use for management.
