Management Issue
Hello,
we have a ptp link with force 300, ( we use it for backup).
i can not manage the Master.
ping is OK,
ethernet interface 1000 full duplex ( i see on mikrotik),
i can manage the slave
i can make wireless link test from the slave
i can upgrade/downgrade the Master through cnMaestro
i can not manage neither by web/ssh/telnet (ip or MAC).
please any sugestion what else to try remotely.
Thank you.
It sounds like you are attempting to manage the master from behind the slave side of the link, is that correct?
There is something very wrong with the way either firewall or bridge filtering rules are configured under the hood on ePMP radios when used in a PTP setting. You can only access the master from the ethernet side of the radio (even a few hops away), but not from the radio side. It doesn’t matter if you have management access set to “ethernet and wireless”.
I’ve been meaning for a long time to write a detailed post about this problem. Maybe now I should.
