Has one had an issues where setting both the Management VLAN an access via HTTPS (Secure) on a STA, locks you out of the device.
To answer the obvious, yes we checked to make sure we’re accessing using a tagged interface. (In fact it works, with a VLAN and without HTTPs just fine.)
We also made sure that we’re accessing via the correct secure port and specifying “HTTPS://”
And the VLAN Membership table is populated correctly. (Again, VLAN works perfectly until I turn on HTTPS)
Try it out for yourself.
Glenford,
We have fixed this issue in the latest software release for ePMP. you can download software version 2.1 from here: https://support.cambiumnetworks.com/files/epmp
