Managing Cambium APs with Xircon
The Xircon application discovers correctly the Cambium APs, at least in my case, I use Xircon since Xirrus invented it.
But in the case of Cambium APs, Xircon cannot enter in console mode to edit and monitor the AP, evidently this is because the Xircon protocol is not implemented in the AP management accesses.
It would be great if this were possible, Xircon is a tool with tremendous potential.
Hi Eduardo, you are correct and I hear you. Since the Xircon can discover the Cambium APs, once discovered, you can launch a SSH session and SSH into the Cambium AP.
Also, Cambium APs can discover other Cambium APs and Xirrus APs using the XRP protocol using the service show XRP-neighbors command.
Thank you Gary,
I use the application in Windows, it is very comfortable to work directly by opening sessions in tabs, this allows me to use my library of scripts very quickly, it is a great tool, in this listing there are Cambium and Xirrus units, and I can only edit the Xirrus units.
