Summary:
The article provides details on profiles in XMS-C and the max profiles that can be created.
The maximum number of profiles that can be created in XMS-C is 1000+
XMS provides profiles for ease of management. A profile allows you to specify a set of APs and manage them as a group. After creating a profile, you then define a uniform configuration and software release to be applied to all the member APs and switches.
This “manage by network” feature eliminates the time consuming and error-prone task of configuring and managing APs individually and ensures the deployment of consistent software and settings across each profile. You can add APs to the profile at any time, before or after entering its configuration and software version settings.
Related Information:
