Is there a published chart anywhere for required signal level based on MCS value for the EPMP1K/2K/3K? I've looked in the manual and can't seem to find it (unless I've missed it), but I'm really needing it for a project I'm working on.
Sensitivity data is already integrated into LINKPlanner tool.
I'd suggest using LINKPlanner Tool and Capacity Calculator Tool.
https://support.cambiumnetworks.com/files/epmp/
Thank you.
The project I'm on doesn't allow for linkplanner use I'm generating coverage plots in EDX.
The Capacity Planning Tool is excel based, and can report what you're looking for in cells that you can copy/paste into your other network planning tools.
@bshiers82501 wrote:Is there a published chart anywhere for required signal level based on MCS value for the EPMP1K/2K/3K? I've looked in the manual and can't seem to find it (unless I've missed it), but I'm really needing it for a project I'm working on.
This what you need?
It is!! Do you happen to have this for 5.4Ghz and 5.1GHz?
No, this is the only one I have ever seen. It is in the Frequency Reuse manual.
Sure enough didn't think to look there!!! Thank you much sir that gets me what I need to start at least!
2 posts were split to a new topic: PMP450m MCS Sensitivities
