I'm working on a project to supply internet to the complex attached. Every unit will not have internet so mesh will be a requirement. We have a few implementations utilizing UBNT and Open-mesh with fairly successful results. I didn't know that the e400 line was capable of mesh so I'm in the process of doing some research to see if it will meet our needs. I just watched the webinar and still have a few questions when anyone has a moment.
remote wifi password change capabilites through maestro?
auto meshing between closest base if they all have the same SSID or do they have to be hardset to a specific base?
multi SSID per AP capable, for example AP1, SSID1=unit number / SSID2=globalSSID / SSID3=privateSSID / SSID4 =meshID? then AP2, SSID1=unit number / SSID2=globalSSID / SSID3=privateSSID / SSID4 =meshID? / AP3, etc etc...
each base can only support 5 clients, is that meshed e400's or actually clients connected to the wifi? What happens to the 6th do they bounce to another AP or base?
Are there any options to switch the meshed ap to a different base remotely if the base goes down or if there is one with a better signal?
mesh can only be enabled on 1 frequency, 2 or 5, is it still usable for other SSID's on that same frequency?
if channel interference becomes an issue does the base automatically change and will the mesh clients also change or do they have to manually be set to reconnect to the base. How does that work with the auto channel selection?
throttling is a capability, but is that per AP or can that be set per SSID?
zero-handoff between AP's?
Can SSID's that are broadcasted have different settings? SSID1=client isolation SSID2=network browsing enabled
I would like this to be as automated as possible, are there rules or fallback options that can be implemented to insure an AP doesn't go down? Everything I've read so far it all seems to be in config and I just want to make sure that if we need to make changes we won't have to make a visit to the house to make that change. Thanks for the feedback and any other suggestions are welcome.
remote wifi password change capabilities through maestro?
Ans. Yes, can be done from template based config change. first do it for Mesh Clients and then for Mesh base.
Ans. It is Auto meshing to the closest AP and derived on signal strength when they have same SSID.
Ans. Yes this is supported.
Ans. This is meshed AP number. 6th mesh clients will be denied of association.
Ans. If mesh base goes down and a redundant base is available nearby with same capabilities, then all mesh clients will go for that.
Ans. Yes it is available for other SSID on same frequency. say you created mesh link on 5ghz
On WLAN1, after that you can create SSIDs on other WLANS and use normal clients. Please note that overall bandwidth will be shared even with mesh clients and hence throughput will be a bit lower than a normal profile.
Ans. This is derived as per mesh base channel whenever they are not in same channel, mesh clients will start scanning of base and move to that. we are coming with one more step in this called mesh recovery which will be available from next software version.
Ans. Throttling is applicable per SSID.
Ans. A normal handoff goes smooth between two mesh clients.
