Hi all,
I set a mesh scenario with 1 e410 as a BASE and 2 e500 as a CLIENTS and that is working fine. A third SSID is set for wireless clients access and is working well too, all clients in that SSID have network access.
At one e500 (mesh client) I want to put an ethernet enabled printer on the Ethernet 2 port but it doesn't get network access. If I connect the Ethernet 1 to the LAN (mesh goes down in this client) the printer gets into the network. I change the printer for a laptop and all happens the same.
Is it possible to do this use case? Any advice is welcome.
v. 3.11.4-r9
Regards...
