Hi, there is a particular problem for this message in red? How it is fixable? Where is in the AP or SM the value for the "Out of range"?
SM ******System Startup****** System Reset Exception -- User Initiated Reset Software Version : CANOPY 14.2 (Build 15) SM-AES Board Type : P11 Boot Bank : 0 Board Temperature : 46 C / 116 F Device Setting : 5.4/5.7GHz MIMO OFDM - Subscriber Module - 0a-00-3e-b3-XX-XX<br />No valid accounts configured. Using default user account FPGA Version : 040716 FPGA Features : AES, Sched; 05/18/2016 : 21:25:02 CET : :Timezone set to CET; 05/20/2016 : 06:20:07 CET : Sector Spectrum Analysis complete for 16 minutes 40 seconds. Previously connected to AP: 0a-00-3e-a0-XX-XX; 05/20/2016 : 18:43:26 CET : :BER counters are out of range! PktCount=1 QPSK A=349 B=804 |
Receive Power : | -57.9 dBm ( -60.0 dBm V / -62.0 dBm H ) |
Signal Strength Ratio : | 3.0dB V - H |
Signal to Noise Ratio : | 31 V / 29 H dB |
Beacons : |
100 % |
Receive Fragments Modulation : | Path V:QPSK:41% 16-QAM:41% 64-QAM:17% Path H:QPSK:35% 16-QAM:33% 64-QAM:32% |
Latest Remote Link Test Efficiency Percentage : |
NA % |
BER Total Avg Results : | 8.097635e-03 |
Beacons Received Last 15 minutes : | 0/0/0% (min/avg/max) Note: The SM needs to be in session for at least 15 minutes. |
Uplink Status
Transmit Power : | 21 dBm |
Max Transmit Power : | 22 dBm |
Power Level : | -59.2 (-64.0 V / -61.0 H) dBm |
Signal Strength Ratio : | -2.0dB V - H |
Signal to Noise Ratio : | 36 dB V / 31 dB H |
NA % |
Local Status
Session Status : |
REGISTERED VC 21 Rate 8X/6X MIMO-B
Latest Local Link Test Results
Stats for LUID: 5 Test Duration: 2 Pkt Length: 1714 Test Direction Bi-Directional RF Link Test VC Downlink Uplink Aggregate Packet Transmit Packet Receive Actual Actual
Efficiency Downlink Uplink Efficiency Fragments count Signal to Noise Ratio Efficiency Fragments count Signal to Noise Ratio Actual Expected Actual Expected
Link Quality Downlink RF Path Modulation Fragments Modulation Percentage Average Corrected Bit Errors
Uplink RF Path Modulation Fragments Modulation Percentage Average Corrected Bit Errors
Link Test ran on 12:20:37 05/26/2016 CET Currently transmitting at:
Receive BER Results
Current Receive BER modulation: QPSK Total bits received : 572322008 Vertical: QPSK: Bit Errors: 292033569 Bit Error Rate: 3.662182e-03 Horizontal: QPSK: Bit Errors: 999474348 Bit Error Rate: 1.253369e-02 Combined BER: 8.097933e-03 |
