Will mikrotik Hap ac lite power the new epmp force 300- 16 and 25.
It will if you swap the blue and brown pairs on one end or the other. Unfortunately Cambium chose to go back to the old reverse polarity POE on these models.
ok only the 300-16 the 300-25 no.
ok thanks.
