Minimum SM Height Released for cnHeat LOCATE Heat Maps!
The Minimum SM Height feature is released for cnHeat LOCATE heat maps today!
Minimum SM Height shows the best location (latitude, longitude, and height) to install an SM for any property.  Minimum SM Height extends cnHeat LOCATE heat maps by providing control over the installation heights and signal levels shown.  A service provider can change SM installation height from 1’ to 80’ in order to see the minimum height at which service can be made available for a potential customer.
SM Height configurable from 1’ – 80’. Signal Strength configurable from -40 to -100 dBm. Set to 41’ and -80 dBm in this picture.
Minimum SM Installation Height of 24’ found at back of property. Left picture is height of 23’ with no coverage.  Right picture is height of 24’ with coverage.Minimum SM Installation Height of 24’ found at back of property. Left picture is height of 23’ with no coverage. Right picture is height of 24’ with coverage.
Minimum SM Height allows for viewing of coverage to be easily toggled from Signal Strength mode to SM Height mode.  This allows for a quick understanding of the Signal Strength level in dBm that will be realized in addition to where installation should optimally occur.
Minimum SM Height toggled to Signal Strength mode shows Signal Strength that will be realized at back of yard.Minimum SM Height toggled to Signal Strength mode shows Signal Strength that will be realized at back of yard.
GPS coordinates for installation also are provided by clicking on the desired spot of installation.
Clicking on installation location provides latitude and longitude.Clicking on installation location provides latitude and longitude.
Excellent work guys.  High Value!!
