Hi guys
After upgrade to 20.2.1 last night, most of our SM have very low Modulation and Sector Frame Utilization shot up
Hi guys
This is most likely because some or all of your SM’s are still running a firmware revision prior to R20. Please update all your SM’s to 20.2.1.
From the release notes:
450M AP only one SM did not upgrade to 20.2.1 was still on 16.1.1.1
But latency on all sm jumps around 160ms to 3400ms
5Ghz freq is used all over our network
As I said and showed you in the release notes, you must upgrade your AP and SM’s to 20.2.1 or they’ll be stuck on 2X modulation.
This is most likely because your frame utilization is maxed out from all your SM’s being ‘stuck’ at 2X modulation.
