nbctcp
(nbctcp)
April 1, 2019, 5:51am
#1
HW INFO:
-MacBook Pro 13" 2013
-e410 firmware 3.10.1-r2
SW INFO:
-mojave 10.14.4
-freeradius
PROBLEMS:
-only from mac os mojave has problem connecting WPA2 Enterprise.
High Sierra according to forum no problem at all
username and password all correct because I can connect from iPad Mini1
Tried various method here with no luck
QUESTIONS:
1. anyone have success with mojave connection to WPA2 Enterprise?
tq
ssn001
(ssn001)
April 1, 2019, 6:36am
#2
Could you please run freeradius in debug mode freradius -XXX and paste the logs. It could have happened because the server certificate or CA certificate is being rejected by Client.
nbctcp
(nbctcp)
April 1, 2019, 9:54am
#3
Here debug output
UPDATE1:
-I suspect my problem because I am using old binary for windows as described here
http://freeradius.1045715.n5.nabble.com/EAP-TLS-failure-td5751961.html#a5751962
UPDATE2:
1. need to use freeradius ver 3.0.17
2. need to edit these files
# vi /etc/freeradius/3.0/clients.conf
# vi /etc/freeradius/3.0/users
# vi /etc/freeradius/3.0/sites-available/inner-tunnel
-check quick config with
# freeradius –CX
-debug config with
# freeradius –X
-if all ok start service with
# service freeradius start
MAC:
-always turn off wifi then turn on back when you want to change username.
otherwise connection failed and no respond in freeradius debug mode
