When the feature is enabled, pop interface is monitored and if its down, Layer 2 tunnels move to next best PoP.
The feature is applicable when static routing is used and IPv4 gateway is configured
Configuration
Onboard controller
On PoP, Enable/Disable option is available in Networking → L2 section
cnMaestro
FAQ
Why is the feature applicable only when static routing is used and not BGP ?
When BGP is used and PoP interface goes down, BGP session goes down as well. And layer 2 tunnels move to next best PoP. Special monitoring of interface is not necessary.
Why is it compulsory to configure IPv4 Gateway. How is it applicable for this feature ?
Whether the interface is down is judged by monitoring the activity on pop interface. When no packets are received , gateway’s reachability is checked by sending an ARP packet.
