Does eptp 1000 & 2000 support multichannel means i have a sector tramitting a frequency 5800 and connected with 10 users but one of user is in very dense noisy area where use of 5800 channel not possible what can i do in this case ?
You will need an ap for each channel you want to use. Also, check out rf element horns if noise is an issue. You can use the 18db horn for a cpe antenna if needed to clear side and rear noise. (The connectorized cpe)
Hmm chris thanks for the reply, i think cambum authorities need to do some thing special in this case no one want to add another AP for a one or two users.
