NAT entry
Hi there!
Is there any chance in a future to have more than 16max entry in port forwarding?
Thx!
A
Thank you fot your feedback.
Unfortunately we are not going to expand number of Tables entries in the nearest future.
Could you please describe your scenario and I will try to propose you some workaround ?
Thank you.
thx fedor
my scenario is to open some ports for my surveillance (usually 3 ports each camera). I have 10 cameras.
Two points: don't want use an external router, just have my e180 configured as PPPoE router, and second, don't want to use any DMZ
