Need help diagnosing Aux port on 4600C
Hi, I am desperately in need of someone’s help in troubleshooting an issue with SFP port on a 4600c not communicating with a mikrotik SFP port. I tested both modules and fiber cable before climbing, I plugged one end into the sfp module on mikrotik and I put the other module into sfp port of our cnmatrix switch and communication/negotiation was complete and working. I took the sfp module from the matrix and climbed and put it, and the fiber, into the 4600c. Mikrotik end recognizes the sfp module and shows no link. 4600c shows aux port down.
They should have had 2.5g Ethernet.
Totally agree, I rebooted the radio once I unplugged and plugged back in the sfp module from the radio and it started communicating. Will be keeping a close eye on it.
Hello, Check the SFP Negotiation.
