We had an AP loose it's GPS sync.
Software version 2.4.2
GPS is up to date with version AXN_1.51_2838
No other AP at the site lost GPS sync.
This is from the log. Any ideas?
Aug 28 11:50:08 Park_ePMP04 kernel: GPS Sync Lost. (17:50:08:676658)
Aug 28 11:50:08 Park_ePMP04 kernel: All STAs disassociated. IEEE80211_REASON_TDD_STOP (20)
Aug 28 11:52:08 Park_ePMP04 kernel: Reseting On-Board GPS.......
Aug 28 11:52:08 Park_ePMP04 kernel: $PGACK,101*42
Aug 28 11:52:08 Park_ePMP04 kernel: $PGACK,201*41
Aug 28 11:52:08 Park_ePMP04 kernel: $PMTK011,MTKGPS*08
Aug 28 11:52:08 Park_ePMP04 kernel: $PMTK010,001*2E
Aug 28 11:56:08 Park_ePMP04 kernel: GPS Sync Restored. (17:56:08:183566)
Aug 28 11:59:07 Park_ePMP04 kernel: Flags 0, Scheduler Mode 0
Aug 28 11:59:07 Park_ePMP04 kernel: **RX stuck: issue1; workaround, HAL restart! badkey_wbufdrop:2269 rxstate_18:0 no_rxintr_count:0 rxeol:3083 rxorn:8
Aug 28 12:04:11 Park_ePMP04 kernel: Flags 0, Scheduler Mode 0
Aug 28 12:04:11 Park_ePMP04 kernel: **RX stuck: issue1; workaround, HAL restart! badkey_wbufdrop:2270 rx state_18:0 no_rxintr_count:0 rxeol:3084 rxorn:8 I keep getting this message in the log.
Aug 28 14:06:48 Park_ePMP04 kernel: Flags 0, Scheduler Mode 0
Aug 28 14:06:48 Park_ePMP04 kernel: **RX stuck: issue1; workaround, HAL restart! badkey_wbufdrop:2279 rxstate_18:0 no_rxintr_count:0 rxeol:3093 rxorn:8
Aug 28 14:07:05 Park_ePMP04 kernel: Flags 0, Scheduler Mode 0
Aug 28 14:07:05 Park_ePMP04 kernel: **RX stuck: issue1; workaround, HAL restart! badkey_wbufdrop:2280 rxstate_18:0 no_rxintr_count:0 rxeol:3094 rxorn:8
Aug 28 14:07:53 Park_ePMP04 kernel: Flags 0, Scheduler Mode 0
Aug 28 14:07:53 Park_ePMP04 kernel: **RX stuck: issue1; workaround, HAL restart! badkey_wbufdrop:2281 rxstate_18:0 no_rxintr_count:0 rxeol:3095 rxorn:8
Aug 28 14:52:26 Park_ePMP04 kernel: Flags 0, Scheduler Mode 0
Aug 28 14:52:26 Park_ePMP04 kernel: **RX stuck: issue1; workaround, HAL restart! badkey_wbufdrop:2282 rxstate_18:0 no_rxintr_count:0 rxeol:3096 rxorn:8
Aug 28 15:42:46 Park_ePMP04 kernel: Adding WDS entry for 1c:b7:2c:7c:1a:44, through ni=00:04:56:c8:c7:fe
Aug 28 16:03:24 Park_ePMP04 kernel: Adding WDS entry for 94:10:3e:fa:3e:f4, through ni=00:04:56:c8:95:7c
Aug 28 16:21:39 Park_ePMP04 kernel: Flags 0, Scheduler Mode 0
Aug 28 16:21:39 Park_ePMP04 kernel: **RX stuck: issue1; workaround, HAL restart! badkey_wbufdrop:2283 rxstate_18:0 no_rxintr_count:0 rxeol:3097 rxorn:8
Aug 28 16:25:41 Park_ePMP04 kernel: Flags 0, Scheduler Mode 0
Aug 28 16:25:41 Park_ePMP04 kernel: **RX stuck: issue1; workaround, HAL restart! badkey_wbufdrop:2284 rxstate_18:0 no_rxintr_count:0 rxeol:3098 rxorn:8
Is the AP telling me the work around is to reboot the AP?
Chris_Bay
(Chris_Bay)
August 29, 2015, 2:26am
#2
You can likely increase your GPS sync hold off time to mask the problem until you’ve resolved the problem correctly also. That setting is configuration > radio, and the very bottom of the page, set it to a very large time to allow your ap to recover that error until the problems worked out. I haven’t came across that particular issue before, we did a long time ago have a similar problem with a sync pipe and the root cause was low voltage to the device, changing the power supply in that instance fixed it. Probably not the case for you though
LBNL
(LBNL)
August 17, 2018, 2:21pm
#3
Sorry to dig up an old thread but we're also seeing this on a connectorised radio:
Sep 3 01:49:14 s2pp2 kernel: [179359.650000] **RX stuck: issue2; workaround, HAL restart! badkey_wbufdrop:115 rxstate_18:33 no_rxintr_count:4708 rxeol:4839 rxorn:231
Sep 3 01:51:43 s2pp2 kernel: [179508.200000] SlotTime 9, AIFS 1, GTT 100, SIFS 14, CCA Threshold -47
Sep 3 01:51:43 s2pp2 kernel: [179508.200000] cca init -> weak = 2 strong = 10 -> done
Sep 3 01:51:43 s2pp2 kernel: [179508.200000] **RX stuck: issue2; workaround, HAL restart! badkey_wbufdrop:115 rxstate_18:33 no_rxintr_count:4709 rxeol:4840 rxorn:231 Radio uptime is low, fw version is 3.5.1
Anyone able to help please?
LBNL
(LBNL)
December 15, 2018, 2:30pm
#4
And anther PtP link on 2.6.1:
Dec 15 14:10:08 s04pp1 kernel: cca init -> weak = 2 strong = 10 -> done Dec 15 14:10:08 s04pp1 kernel: **RX stuck: issue2; workaround, HAL restart! badkey_wbufdrop:0 rxstate_18:0 no_rxintr_count:31 rxeol:29 rxorn:0 Dec 15 14:10:08 s04pp1 kernel: SlotTime 9, AIFS 1, GTT 100, SIFS 14, CCA Threshold -53 Dec 15 14:10:08 s04pp1 kernel: cca init -> weak = 2 strong = 10 -> done Dec 15 14:10:08 s04pp1 kernel: **RX stuck: issue2; workaround, HAL restart! badkey_wbufdrop:0 rxstate_18:0 no_rxintr_count:32 rxeol:30 rxorn:0 Dec 15 14:10:09 s04pp1 kernel: SlotTime 9, AIFS 1, GTT 100, SIFS 14, CCA Threshold -53 Dec 15 14:10:09 s04pp1 kernel: cca init -> weak = 2 strong = 10 -> done Dec 15 14:10:09 s04pp1 kernel: **RX stuck: issue2; workaround, HAL restart! badkey_wbufdrop:0 rxstate_18:0 no_rxintr_count:33 rxeol:31 rxorn:0 Dec 15 14:10:09 s04pp1 kernel: SlotTime 9, AIFS 1, GTT 100, SIFS 14, CCA Threshold -53 Dec 15 14:10:09 s04pp1 kernel: cca init -> weak = 2 strong = 10 -> done Dec 15 14:10:09 s04pp1 kernel: **RX stuck: issue2; workaround, HAL restart! badkey_wbufdrop:0 rxstate_18:0 no_rxintr_count:34 rxeol:32 rxorn:0 Dec 15 14:10:09 s04pp1 kernel: SlotTime 9, AIFS 1, GTT 100, SIFS 14, CCA Threshold -53 Dec 15 14:10:09 s04pp1 kernel: cca init -> weak = 2 strong = 10 -> done Dec 15 14:10:09 s04pp1 kernel: **RX stuck: issue2; workaround, HAL restart! badkey_wbufdrop:0 rxstate_18:0 no_rxintr_count:35 rxeol:33 rxorn:0 Dec 15 14:10:09 s04pp1 kernel: SM[00:04:56:f8:73:9b] aid=1 disassociated. Reason: COMMUNICATION LOST Dec 15 14:10:09 s04pp1 hostapd: ath0: STA 00:04:56:f8:73:9b IEEE 802.11: disassociated Dec 15 14:18:01 s04pp1 hostapd: ath0: STA 00:04:56:f8:73:9b IEEE 802.11: associated Dec 15 14:18:01 s04pp1 hostapd: ath0: STA 00:04:56:f8:73:9b RADIUS: starting accounting session 55E4EA8A-0000000F Dec 15 14:18:01 s04pp1 hostapd: ath0: STA 00:04:56:f8:73:9b WPA: pairwise key handshake completed (RSN)
