Hello Everyone,
I hope you are doing well.
I am currently working on a Cambium Networks wireless setup and facing an issue with link stability. The connection sometimes becomes unstable and I notice slight packet loss during peak usage.
My setup details:
Cambium ePMP / (you can edit model)
Point-to-Point link between two sites
Distance: approx. (add your distance)
Firmware version: (if known)
What I have already tried:
Checked alignment of antennas
Rebooted both radios
Reduced interference by changing channel
But the issue is still there.
Can someone please suggest what else I should check or any best practice to improve link stability?
Any help would be appreciated.
Thank you in advance.
