Greetings (this will be my first post so bare with me )
We use Cambium equipment in wiFi4EU projects and projects for our business clients who wanted better indoor WiFi.
But our company also has already made some success stories in the field of WISP, we offer IT services (internet, television and telephony) to costumers who do not have the possibility of access to a good DSL line or optical fiber.
As user needs for larger internet connection speed grow as the current situation progresses, we are forced to upgrade some existing point-2-multi-point networks.
We are currently using Mikortik equipment, which unfortunately can no longer meet the needs. So we started looking after other manufacturers.
So I would ask if anyone can comment on my ideas (is the correct equipment used, other ideas, …?).
- network/site upgrade
- 15 connected users who have an average internet connection speed of 30/10 Mbps per user.
- Users are 50 to 700 meters away from the access point and have clean LOS.
Our wish is to replace all existing Mikortik Equipment with Cambium portfolio and add about 3 more customers to the new access point and for each customer (as old as these five new ones) to have a 40/20 Mbps internet connection.
Link planner suggested ePMP450i but there was not an option Slovenia for country so I changed to ePMP3000L (with Cambium Networks 90° 5 GHz Sector Antenna) for the base access point and ePMP force 130
Performance summary says that predicted throughput will be 176Mbps DL / 57 Mbps UL (is that number actual throughput for one costumer?)
- 18 connected users who have an average internet connection speed of 30/10 Mbps per user.
- Users are 3km to 4 km away from the access point and have clean LOS.
Our wish is to replace all existing Mikortik Equipment with Cambium portfolio and add about 5 more customers to the new access point and for each customer (as old as these five new ones) to have a 40/20 Mbps internet connection.
Link planner suggested ePMP450i but there was not an option Slovenia so I again changed to ePMP3000L (with Cambium Networks 30° 5 GHz Sector Antenna) for the base access point and ePMP force 180 - or ePMP force 200
I played also with ePMP 2000 and the results ware in the range of 3000L
Can anyone suggest in which direction should we go, is used equipment ok for both scenarios, …?
