I noticed a few of our new 5ghz GPS lite APs have a new firmware in them
AXN_3.20_8174
is ther any diffrences in these units compared to the 2838 chips/versons?
AXN_3.20_8174
Thanks Eric!
I'm having an issue with an ePMP 1000 not seeing any satellites with the puck hooked on to it. Before the puck it would see internal Satellites. Not sure whats up with it. I'm on 2.6.1
@kmitre wrote:I'm having an issue with an ePMP 1000 not seeing any satellites with the puck hooked on to it. Before the puck it would see internal Satellites. Not sure whats up with it. I'm on 2.6.1
I assume the puck is outdoors and it has a clear view of the sky? And if yes, is it near any high powered RF equipment, like FM transmitters or cellular equipment?
Not near FM transmitter. And yes it's outdoor and clear LOS.
@kmitre wrote:Not near FM transmitter. And yes it's outdoor and clear LOS.
Do you have another puck you could try?
It ended up being something with the firmware on 2.6.1
I had to re-update the firmware and then do a factory reset to make it work.
