no (capacity is zero)
Good afternoon!
I need help for the following problem, I have a cambium network with several SMs force 180, force 200,
APs ePMP 2000 the APs are with the full license ok to allow up to 120 connected SMs
but does not allow it to add + 10, all SMs that I try to add shows the message "no (capacity is zero)".
Do you have any other settings that I should change besides including the license? I thank you for your help! Rogério Andrade.
Max Registration Allowed on Configuration->Radio page should be configured to 120 or any other value you’d like to allow.
Thank you.
