We are using CNUT 4.10.. We have a couple of PMP450 APs thet keep giving this error No SNMP response. We have rebooted the AP, and tried again. We have compared settings the same on Aps that work. Any suggestions.
Kurt
Kurt
This means CNUT tries to get data from APs over SNMP.
Please check your snmp configuration snmp community string, version in cnut as well as on AP.
How about the SMs,Are you able to upgrade the SMs?
If both AP and SM have the same SNMP settings and read & write is enabled , the AP and SM should communicate to the Cnut server.
In case if the issue stille persists,Please send us an email at support@cambiumnetworks.com with your details.We will contact you to assist you.
